| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I am installing a Clifford 4 barrel manifold on a 261 and realize there is shift linkage interference with the column shift. We are swapping the trans to a floor shift, so we will be ok. But, I am wondering what others may have done if they had the same problem. Any thoughts?
Drew
| | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | I think Cosmo fabbed up offset arms for the shifter. I am going to run into the same problem as I am going to hang a 4-71 blower off the side of BillyBob's 235 stovebolt. I plan on following Deve's instructions to mount a 3-speed floor shifter like a top-loader.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thanks Larry for reminding me of Cosmo's fabrication on the linkage. I'll do a search about it. We are planning to go to a T5 which will eliminate the trouble, but add other issues. LOL. Seems to me I saw a 235, maybe 261, blower set up recently. I'll have to look into that too.
Drew
