| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 3 New Guy | | New Guy Joined: May 2015 Posts: 3 | Can anyone tell me the trick to disassembling the glove box latch. Trying to get it off to paint the door. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I can't speak to that era other than to say "In General" they liked things like C clips and 'wavey' or spring washers 'back in the day'. Sometimes pushing or pulling against the spring washer while twisting to get the barrel to line up with a notch in the door allowing the barrel to slide out is a solution.
The engineering used usually had a 1930's quantity of "Common Sense" about it that oft eludes Us more modern types...
| | | | | Joined: May 2015 Posts: 3 New Guy | | New Guy Joined: May 2015 Posts: 3 | Thanks, but this is different, I think the plundger has to come out to get this apart. I even took it to a body shop that pretty much works on older cars, he was stumped. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi SEPPIE, welcome aboard. I recently removed the latch on my 36 GMC glove compartment door for painting. I have the latch at my work place. I'll look at it tomorrow to refresh my memory. I'm in the process of restoring that 36 GMC. I have pictures and experience with everything on that truck, if I can be of help. Regards, John | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | Pull the square outward from the back of the lock, jiggle the key and the key comes out as does the latch. To reassemble, push the latch in until it clicks, look into the lock cavity and push the latch just enough to see the indention in it, push the cylinder in (with the key in it) and the peg on the back of the cylinder lined up with the indention on the latch, turn the key and it will click into place.
| | | | | Joined: May 2015 Posts: 3 New Guy | | New Guy Joined: May 2015 Posts: 3 | THANKS, dunfire it came apart just like you said,i really appreciate your help. Thanks again, Seppie | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi SEPPI, I looked at my disassembled latch today. I didn't have a key for my lock like Dunfire above. I removed the 1/4 inch wide spring clip on the latch mechanism and the latch came out so I could remove the mounting nut. | | |
