0 members (),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | ssrjim- good work on the seat! Thx for your blog link. Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I agree with the "Horse" on this. Can you pull it and somehow get it on a lathe to check the balance.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jock, out of balance drive shaft? Just an idea. It's one of the things I'll be getting checked Martin,it was a brand newshaft,fully balanced etc. I'm suspecting pinion angle or possibly the rear UJ. While I had the shaft out to install my new rear 4-link one of the bearing cups came off along with some needle bearings,i'm wondering if I screwed up the refit. The problem seems to have got progressively worse since then. Whatever's happened it's spoiling my fun,I just wish it would stop biting me on the a..!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | U-Joints can be very tricky and I too have messed up 1 or 2 over the years.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I fixed the oil leak in the Suburban. Last fall I put a 235 balancer on it. Worked fine but the pulley was larger and turned my water pump and alternator faster. Also it started leaking oil from the front after I changed it.
I cleaned up a 248 balancer and put a speedy sleeve on it. I changed it out today and found out that ol' boy didn't tighten the bolts on the timing gear cover. No wonder it was leaking oil.
All back together now with tight bolts and 248 balancer. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I can relate to that Cletis. Yesterday I was wiping down all the shiny parts on the engine and noticed a loose valve cover bolt. I tightened it then noticed the next two on that side were also loose. Sure enough the three bolts on the other side were also loose. I somehow neglected to tighten them when I originally put those covers on back in 2008 when the engine was new. Amazing that there were no leaks. However it has only 1900 miles on it.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I cleaned up a 248 balancer and put a speedy sleeve on it. Speedy sleeve? Please explain....  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://www.skf.com/us/products/seal...ear-sleeves/skf-speedi-sleeve/index.htmlPost your engine make/size and maybe someone will post a part number for the appropriate Speedi-Sleeve? Also sold as Harmonic Balancer Repair Sleeve by other manufactures, such as National. Similar repair sleeves are also commonly used on axles where axle seals have worn grooves axles. | | | | | Joined: Aug 2014 Posts: 213 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 213 |
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | got the transmission bolted to the crossmember in the sub. the 283 is now located fore and aft. need to level up the engine side to side and fab some front mounts. going slow but it is going. Hope to get it done before running out of cruising weather, Install fuel pump and distributor next followed by alternator Power steering pump belts and hoses.
Weeds | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I got the rear bumper off. I started taking the front fenders off so I can patch them. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I hope Marge enjoys her vacation to sunnier climes.  That's "Monkey business" you don't mind.....  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Speedi-Sleeve? Also sold as Harmonic Balancer Repair Sleeve by other manufactures, such as National. Similar repair sleeves are also commonly used on axles where axle seals have worn grooves axles. Thanks for the link Tim,it confirms my suspicions.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Toomany2count, Is the suburban in the photobucket display yours? Large Marge?
Weeds | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Pulled the axles and replaced the rear axle seals. Rebuilt the rear wheel cylinders too. Tomorrow rear brakes. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Worked on my gauge project Pic Pic ...test... | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Got the replacement 235 on the stand and tearing down for inspection and reseal if its good enough to just drop in. | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | - Pulled the front clip off of the '47 (with help from my wife and 14 year old son) and started removing the accessories to move them onto the '51 "transplant" engine. - Greased the steering box with corn head grease (so easy to get to with the clip off) - Cleaned up the distributor and replaced the vacuum advance - Painted the t'stat housing, water pump, and damper to match the replacement engine. - Cleaned the fuel pump - Pulled the manifold assembly and finally got the heat flap freed up.
A busy few days and evenings, but a lot of good greasy fun, or as my family says: "Dad's threaded fastener therapy sessions"!
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Aug 2014 Posts: 213 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 213 | I hope Marge enjoys her vacation to sunnier climes.  That's "Monkey business" you don't mind.....  I'm sure she'll be wearing her sun screen & sun glasses while "monkeying" around down south & will be massaged into shape  before returning home later this year. Toomany2count, Is the suburban in the photobucket display yours? Large Marge? Weeds If it's on my Photobucket page then yes that's mine. BUT it's not a suburban. It's a 1ton panel that was sent to a coach shop & was made into a school bus for the rural school districts. Mine was a bus for St Mary's Cornwin School & Church somewhere in NW Kansas I believe. At one time you could read School Bus above the windshield & you can still barely read the bus number on the drivers door....joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: May 2015 Posts: 177 'Bolter | | 'Bolter Joined: May 2015 Posts: 177 | Put the 67 up on Jack stands to take a look at how to remove the exhaust from the ram horns to get ready to pull the motor. Couldn't get to the three bolts so I started at the exhaust manifold figuring I could just lift it up after I get the ram horns detached from the heads and get the bolts that way. So I got the horns off the passenger side without breaking a bolt thankfully. Next on the to do list is the driver side.
That's for another day. | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Well.... I found out my 30 had water in the gas tank so I had to drain it. I took the carburetor off and cleaned it up. In the process I lost that little steel ball. I clipped the end off of one of my wife's large straight pins and used it. It worked good for a little while but then, by the time I made it back to put the truck away it started back firing. I fond out that gas makes that plastic on those pins soft. I guess I'll have to get a carburetor kit now. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I went up to truckernix's place. Fred adjusted the valves for me, showed me how to do it. I got to hold the light. Left my gas cap at the gas station half hour from home. I grabbed one off the '67, fits. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Got the 37 off the jack stands and ready to see if the rod bearings helped. | | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | Made a cab dolly and placed the cab on it to start putting body panels on.
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | After over 17 years without a bell housing pan , my truck finally has its pants on  | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | After over 17 years without a bell housing pan , my truck finally has its pants on  Mine's 'nekkid' too.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Needless to say, i don't think my wife appreciates my intimacy level obtained with Dolly. Too bad it took all day pounding her with a hammer (yes there was a fender in between!)
I gained a new appreciation for body men/women!
Chris
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Spent yesterday AM modifying the seat brackets on the '48 Burb. When I bought it the configuration was like a California Low Rider from the '80s. I'm 6'2" and could not see over the dash. Seat was mounted flat to the floor. So I raised it 3 1/4 inches. Been driving it that way for a while but got tired of bumping my head on the door frame every time I got in. So yesterday I pulled the seat and chopped the bracket down to 2 1/4. Finally sits just right and no more headaches. While messing around I installed a '53 original 6 volt horn behind the grill. Not wired yet but I'll get to it. Happy motoring!
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | My SM420 was hard to shift, gears would grind. I pulled the trans, disassembled and found the PO/Hack mechanic had installed the wrong scynro in the third to fourth position. First picture is what I found. Second picture is of the correct Made in the USA part. She will now shift like new.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | assembled new rotors, calipers and pads to the Scott Danforth crossmember on the 49 Suburban. Torquing and cotter pinning ball joints this afternoon. I just might get this thing done before it snows again.
Weeds | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Washing, polishing and waxing for this Saturday's show. Normally I don't keep it inside but with all the work done to make her look pretty I'm keeping her in my Daughter's shop around the corner from my house until early Saturday morning.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Wish I could make the show. I want to see that Suburban. | | | | | Joined: Oct 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2014 Posts: 34 | Removed the front leafs and Ibeam in prep for my crossmember install. Also removed the rear axle to ready it for my Zr2 8.5 rear axle.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Cletis, you don't have to wait for the show. You and June are welcome anytime. Drop in on your next voyage to KC.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Good luck Martin. Take some pics.
~Jim
| | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | got the engine compartment primed and painted Waiting on flywheel and trans parts to install the 261. Mtneermike
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Jim, I would love to do photos but I'm extremely tech challenged. Son is a Computer Engineer and I still can't get it.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Got the original '53 horn working on the '48 Burb ----Honk Honk! Charged the A/C, man it's nice to have cold air blowing on your face when it's 90+ outside. Little extra spit and polish and I'm ready for tomorrow.
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Sanding, sanding and more sanding! Getting near the point of being able to spray another layer of primer and then some color. Should probably get that ordered here soon. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Finally got my wiper motor installed and the arms installed. All I need now are the arms for the wipers. Back ordered. I'm really impressed with how easy the wiper motor went in. I got it from Jim Carter and everything was in there to install the motor and hook it to my wiper arms. Larry
58 gmc 100 with 350 sbc
