| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | OK I have read several post here and else where on how to swap a 235 into a 216 truck. The several posts and quick guides I have read talk on taking the two front side mount tabs off and pulling the whole front (balancer, timing cover, pan, cam) to place the front mounted bracket in place. What I see is the 59 used a yoke that sloped forward to mount onto the cross member. The yoke looks to place the mount in the same approximate location as a front mount. So, has any one used this method, is so how did it work and what is needed? If not why not do it that way other then making the 48 look stock for the engine mounting?
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Tim I had seen the diagram, but for my statement I do not desire to spend time and money at this time pulling the valve train apart to replace or drill holes. I am trying to see if some one used the 59 mount as seen in this picture [img] http://www.spicetraders.com/photos/59mm.jpg[/img] and how it was to set up. Or used the mounts as I have found installed on my 59 engine and how they work into the cross arm seen in this picture.[img] http://www.spicetraders.com/photos/59mmcur.jpg[/img] Both are simple bolt ons to the engine no disassembly required. Thx Ron
