0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I was wondering how this would hold up. I would think pretty well. But if it did get scratched or damaged, how do you redo powder coat? Just looking for a more forgiving finish than regular paint. TIA for your comments.
40 Chevy 1/2 ton
| | | | | Joined: Nov 2001 Posts: 11 Junior Member | | Junior Member Joined: Nov 2001 Posts: 11 | If "shiny" is not important, why not try that roll on bedliner stuff, i.e. Rhinoliner. Saw a picture in a rodding magazine where a guy had used the stuff on the top surface of the running boards over shiny paint on the sides. Looked good and should be very servicable. I understand you can recoat the bedliner stuff easily if it gets skinned up. | | | | | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | I thought the same thing. I had a set powdercoated for 80.00 dollars. They were scratched terrible in a week. I took them off and went back to the powdercoater. He re blasted them and called his supplier. The supplier recommended a heavier duty powder with a matt finish. had them re-powder coated ,still didnt last a week. If I do them again I am gonna have them sprayed with the rubberized pick-up box liner like Rhino coating. I have seen this at the shows and it looks good.,but I dont know if it will hold up or if they dont step on them ?? Mike | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I sand blasted a set, epoxy primered and then did a dark gray metallic Imron with clear coat. Stepped on them all the time (as did all my buddies!) never had a problem with scratching them up. Looked good for years after painting. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks for the replys. I think I'll to some kind of paint. I'm pretty happy with Hammerite that I used on the suspension pieces as things were replace. Pretty durable and cheap. Maybe I'll give that a whirl. Hey, thanks again. Dennis
40 Chevy 1/2 ton
