6 members (GRNHydra, Oswald, Southerntruck, 1955 1 Series, Nick in Manitou, Wayne67vert), 122 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
#1100610 05/03/2015 1:04 AM
Want to replace my radiator hoses upper and lower with new hoses. Not having any luck finding replacement hoses. The circumference measurements are as follows, radiator top hole 1 1/4", bottom hole 1 1/2", small short shank water pump outlet 1 3/4", and inlet atop the intake that holds the thermostat is 1 1/2". Does anyone besides me have this same setup and have conquered this problem with correct new hoses that fit or tell me what I have to do. My measurements are very approx. using a tape measure, Thanks HUGH
There's a simple, quick fix that I learned while working in a radiator shop. Buy a flex hose that fits the bigger diameter, such as the 1 1/2" thermostat housing, and cut a short section of 1 1/4" hose to slip over the upper nipple on the radiator. Install this piece on the radiator nipple WITHOUT SEALER OR ADHESIVE and slip the larger hose over it. Clamp it snugly with a worm-drive hose clamp, and it will be secure and leakproof. Do the same thing with the lower hose, adapting the larger diameter hose to the smaller radiator nipple with a reducer sleeve. This has worked for me on race engines with 20+ PSI radiator caps.
Update, found a fix for this problem. Will post again as soon as I can get out and finish this repair. Thanks HUGH
dayco sells hose bushings. available at any napa or car quest.
Finally was able to get out and finish the repair on my 1952 Chevy 1/2 ton pickup with original radiator and a 283 sbc. All 5/8" heater hose replaced today along with 180 degrees thermostat, water pump (short shaft), top radiator hose Dayco #81081, 1 1/4" - 1 1/2" x 15 1/2", bottom radiator hose Dayco #81231, 1 1/2" - 1 3/4" x 13 1/4". Stock radiator was taken out flushed and pressure checked with no leaks and reinstalled. These radiator hoses fit like a glove, exact size and length, really made this repair a breeze. I have the original heater that I had re-cored with a heater core for a mid 60's Ford Falcon. Removed the end caps and had my ends re-soldered onto it to ensure an original fit. Cleaned and repainted all affected areas while everything was out. It has been a busy day thanks to all for your help and inputs. A wealth of knowledge on this site. Thanks HUGH
What style heater takes the Falcon core?
Carl
Not sure how to bring a pic forward to this topic as my son is sleeping and will have to wait til he wakes up, but if you look at my list of all post's there is a picture of that heater, thanks HUGH
