3 members (MickeyP, Joe H, Jon G),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | Did Chevy make a long tail 3 speed trans with overdrive? I'm looking to upgrade my 59 3200 long bed. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't know what you mean by "long tail" but an SM319 OD was an option in '59. It is the same length as the SM318 3 speed. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The SM319 will be a direct fit into a 3200. I have one in mine. Driveshaft first perfectly, no alterations needed.
Bill Burmeister | | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | I have 2 3 speed trans 1 from a 58 short bed truck and 1 from a 59 long bed truck, the tail on the 1 from the 59 is about 4 inches longer than the 58. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Do you have pics of the transmissions? It sounds like the one from the shortbed truck might be the HD 3 speed option, which is a Borg-Warner T-85.
Bill Burmeister | | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | No pics the 59 is in the truck, the 58 is at my brothers house. I do know the 59 is 22 inches in total length with a 15 inch tail and the 58 is 18 about 18 inches total with 1bout an 11 inch tail. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Without seeing the other transmission, it seems that is probably is the HD. The SM318 standard 3 speed is 22 inches long, as is the SM319 overdrive.
Bill Burmeister | | | | | Joined: Feb 2014 Posts: 17 New Guy | | New Guy Joined: Feb 2014 Posts: 17 | Ok Thanks, Now I need to find an SM 319 here local in NW Arkansas | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | @ Callmebob.....find me one too..:)
1959 3100 Apache Fleetside
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | They appear on eBay quite regularly. | | |
