3 members (dt235sd, Peggy M, Shade Baby), 108 guests, and 5 robots.
Topics128,120
Posts1,056,321
Members48,439
#1102957 05/16/2015 1:14 AM
I am new to this forum. I am trying to get my 46 chevy 3/4 ton pickup running. The water pump is shot and I would like to get a replacement. My harmonic balancer pulley has a 3/8 groove, and the the generator pulley is also 3/8. The water pump has a 5/8 pulley. All of the replacement water pumps I see online have 5/8 pulley. Can I run this setup with a 3/8 belt? Can I get a 3/8 pulley on a water pump that will fit this engine? I really do not want to change the harmonic balancer. Thanks for your expertise.
back yard wrench turner
Welcome to the stovebolt.
I had the same issue. The replacement pump was the wrong size. I changed the pulley from the old water pump to the new one.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
If you order a 1953-54 pump it should come with a 3/8" pulley.
My Blog
Thank you for the help
