| | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 5 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 5 | I am new to this forum. I am trying to get my 46 chevy 3/4 ton pickup running. The water pump is shot and I would like to get a replacement. My harmonic balancer pulley has a 3/8 groove, and the the generator pulley is also 3/8. The water pump has a 5/8 pulley. All of the replacement water pumps I see online have 5/8 pulley. Can I run this setup with a 3/8 belt? Can I get a 3/8 pulley on a water pump that will fit this engine? I really do not want to change the harmonic balancer. Thanks for your expertise. | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | Welcome to the stovebolt.
I had the same issue. The replacement pump was the wrong size. I changed the pulley from the old water pump to the new one.
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you order a 1953-54 pump it should come with a 3/8" pulley.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2015 Posts: 5 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 5 | | | |
