2 members (mick53, KEVINSKI), 116 guests, and 2 robots.
Topics128,126
Posts1,056,353
Members48,441
Page 127 of 177 1 2 … 125 126 127 128 129 … 176 177
U
U Offline
ssrjim- good work on the seat! Thx for your blog link.
Brad
Wrench Fetcher, PhD
I agree with the "Horse" on this. Can you pull it and somehow get it on a lathe to check the balance.
~Jim
Originally Posted by Justhorsenround
Jock, out of balance drive shaft? Just an idea.
It's one of the things I'll be getting checked Martin,it was a brand newshaft,fully balanced etc.
I'm suspecting pinion angle or possibly the rear UJ. While I had the shaft out to install my new rear 4-link one of the bearing cups came off along with some needle bearings,i'm wondering if I screwed up the refit.
The problem seems to have got progressively worse since then.
Whatever's happened it's spoiling my fun,I just wish it would stop biting me on the a..! grin
More pix on Flickr.
U-Joints can be very tricky and I too have messed up 1 or 2 over the years.
I fixed the oil leak in the Suburban. Last fall I put a 235 balancer on it. Worked fine but the pulley was larger and turned my water pump and alternator faster. Also it started leaking oil from the front after I changed it.
I cleaned up a 248 balancer and put a speedy sleeve on it. I changed it out today and found out that ol' boy didn't tighten the bolts on the timing gear cover. No wonder it was leaking oil.
All back together now with tight bolts and 248 balancer.
I can relate to that Cletis. Yesterday I was wiping down all the shiny parts on the engine and noticed a loose valve cover bolt. I tightened it then noticed the next two on that side were also loose. Sure enough the three bolts on the other side were also loose. I somehow neglected to tighten them when I originally put those covers on back in 2008 when the engine was new. Amazing that there were no leaks. However it has only 1900 miles on it.
~Jim
Speedy sleeve? Please explain.... headscratch
More pix on Flickr.
http://www.skf.com/us/products/seal...ear-sleeves/skf-speedi-sleeve/index.html
Post your engine make/size and maybe someone will post a part number for the appropriate Speedi-Sleeve?
Also sold as Harmonic Balancer Repair Sleeve by other manufactures, such as National.
Similar repair sleeves are also commonly used on axles where axle seals have worn grooves axles.
I have more zippers then a pair of cargo pants
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
got the transmission bolted to the crossmember in the sub. the 283 is now located fore and aft. need to level up the engine side to side and fab some front mounts. going slow but it is going. Hope to get it done before running out of cruising weather, Install fuel pump and distributor next followed by alternator Power steering pump belts and hoses.
Weeds
I got the rear bumper off. I started taking the front fenders off so I can patch them.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
Originally Posted by TooMany2count
I hope Marge enjoys her vacation to sunnier climes. grin
That's "Monkey business" you don't mind..... wink
More pix on Flickr.
Speedi-Sleeve?
Thanks for the link Tim,it confirms my suspicions. thumbs_up
More pix on Flickr.
Toomany2count, Is the suburban in the photobucket display yours? Large Marge?
Weeds
Pulled the axles and replaced the rear axle seals. Rebuilt the rear wheel cylinders too. Tomorrow rear brakes.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Worked on my gauge project
Pic
Pic
...test...
Got the replacement 235 on the stand and tearing down for inspection and reseal if its good enough to just drop in.
- Pulled the front clip off of the '47 (with help from my wife and 14 year old son) and started removing the accessories to move them onto the '51 "transplant" engine.
- Greased the steering box with corn head grease (so easy to get to with the clip off)
- Cleaned up the distributor and replaced the vacuum advance
- Painted the t'stat housing, water pump, and damper to match the replacement engine.
- Cleaned the fuel pump
- Pulled the manifold assembly and finally got the heat flap freed up.
A busy few days and evenings, but a lot of good greasy fun, or as my family says: "Dad's threaded fastener therapy sessions"!
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
I'm sure she'll be wearing her sun screen & sun glasses while "monkeying" around down south & will be massaged into shape secret before returning home later this year.
Weeds
If it's on my Photobucket page then yes that's mine. BUT it's not a suburban. It's a 1ton panel that was sent to a coach shop & was made into a school bus for the rural school districts. Mine was a bus for St Mary's Cornwin School & Church somewhere in NW Kansas I believe. At one time you could read School Bus above the windshield & you can still barely read the bus number on the drivers door....joe
~ Joe
Put the 67 up on Jack stands to take a look at how to remove the exhaust from the ram horns to get ready to pull the motor. Couldn't get to the three bolts so I started at the exhaust manifold figuring I could just lift it up after I get the ram horns detached from the heads and get the bolts that way. So I got the horns off the passenger side without breaking a bolt thankfully. Next on the to do list is the driver side.
That's for another day.
~ Daniel Davidson
1939/1940 Chevrolet/GMC
Follow his Project Journal
Well.... I found out my 30 had water in the gas tank so I had to drain it. I took the carburetor off and cleaned it up. In the process I lost that little steel ball. I clipped the end off of one of my wife's large straight pins and used it. It worked good for a little while but then, by the time I made it back to put the truck away it started back firing. I fond out that gas makes that plastic on those pins soft. I guess I'll have to get a carburetor kit now.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Leo Offline
Moderator
Moderator
I went up to truckernix's place. Fred adjusted the valves for me, showed me how to do it. I got to hold the light. Left my gas cap at the gas station half hour from home. I grabbed one off the '67, fits.
Got the 37 off the jack stands and ready to see if the rod bearings helped.
RGG Offline
Made a cab dolly and placed the cab on it to start putting body panels on.
After over 17 years without a bell housing pan , my truck finally has its pants on smile
Mine's 'nekkid' too. grin
More pix on Flickr.
Needless to say, i don't think my wife appreciates my intimacy level obtained with Dolly. Too bad it took all day pounding her with a hammer (yes there was a fender in between!)
I gained a new appreciation for body men/women!
Chris
Spent yesterday AM modifying the seat brackets on the '48 Burb. When I bought it the configuration was like a California Low Rider from the '80s. I'm 6'2" and could not see over the dash. Seat was mounted flat to the floor. So I raised it 3 1/4 inches. Been driving it that way for a while but got tired of bumping my head on the door frame every time I got in. So yesterday I pulled the seat and chopped the bracket down to 2 1/4. Finally sits just right and no more headaches. While messing around I installed a '53 original 6 volt horn behind the grill. Not wired yet but I'll get to it. Happy motoring!
My SM420 was hard to shift, gears would grind. I pulled the trans, disassembled and found the PO/Hack mechanic had installed the wrong scynro in the third to fourth position. First picture is what I found. Second picture is of the correct Made in the USA part. She will now shift like new.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
assembled new rotors, calipers and pads to the Scott Danforth crossmember on the 49 Suburban. Torquing and cotter pinning ball joints this afternoon.
I just might get this thing done before it snows again.
Weeds
Washing, polishing and waxing for this Saturday's show. Normally I don't keep it inside but with all the work done to make her look pretty I'm keeping her in my Daughter's shop around the corner from my house until early Saturday morning.
Wish I could make the show. I want to see that Suburban.
RGG Offline
Removed the front leafs and Ibeam in prep for my crossmember install. Also removed the rear axle to ready it for my Zr2 8.5 rear axle.
Cletis, you don't have to wait for the show. You and June are welcome anytime. Drop in on your next voyage to KC.
Good luck Martin. Take some pics.
~Jim
got the engine compartment primed and painted Waiting on flywheel and trans parts to install the 261. Mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Jim, I would love to do photos but I'm extremely tech challenged. Son is a Computer Engineer and I still can't get it.
Got the original '53 horn working on the '48 Burb ----Honk Honk! Charged the A/C, man it's nice to have cold air blowing on your face when it's 90+ outside. Little extra spit and polish and I'm ready for tomorrow.
Sanding, sanding and more sanding! Getting near the point of being able to spray another layer of primer and then some color. Should probably get that ordered here soon.
Finally got my wiper motor installed and the arms installed. All I need now are the arms for the wipers. Back ordered. I'm really impressed with how easy the wiper motor went in. I got it from Jim Carter and everything was in there to install the motor and hook it to my wiper arms. Larry
58 gmc 100 with 350 sbc
