1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Hi my 1954 3100 has a 235 w/ 848 head 1956-57 block...what would be involved in switching the B W 10R transmission to a SM 420? The BW was converted to a floor shift but the stick is not located in the correct location. I love a floor stick shift but I want to replace the BW with SM420 that would relocate the stick shift.....any place where I can find information on this kind of swap? The SM420 is suppose to be bullet proof is there another transmission out there that would give me what I want? Thanks Go Army | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year SM420?
Enclosed drive-shaft (as used in 1954) or other rear end? (most likely, "no").
If other rear-end, what model/year/etc?
That information is needed in order for people to give you useful/helpful information.
| | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | The drive shaft is open. The PO switch out all the running gear the engine and all else is from a 56-57 donor truck. 235 engine of course he chopped the radiator are to fit the newer 235. The transmission is an OD unit Borg Warner with floor conversion shift kit.
Thanks, Steve | | | | | Joined: Sep 2011 Posts: 1,462 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,462 | I (and I'm sure several others) would trade a SM420 for that BW!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Who,Me, The Muncie SM420 was produced by GM from 1947-1967. I had a 1964 Chevrolet truck with the SM 420 transmission that was equipped with the open drive line. If you find a later model Chevrolet truck from the late '50's to the early-mid sixties with the open drive line the conversion from the BW to the SM 420 should be fairly straight forward. If you have detailed questions you want answered contact Novak Conversions www.novak-adapt.com. They should be able to answer most questions. Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | is there another transmission out there that would give me what I want? Thanks Go Army What is it you want? The OD is great for highway driving. The SM420 is great for pulling stumps. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Steve, I don't see any problems with the conversion since you have an open driveline. Have a new driveshaft built to match your SM420, cut a new hole in the floor and you have it. The problem that I see is that you are loosing all the benefits of the overdrive with the conversion. Providing the overdrive is working it has much better highway performance than the SM420. Considering that the stock 55-57 donor truck either had a 3:90 or 4:11 gear set, that would be your final ratio with the SM420 as it is 1:1 in 4th gear. The OD trans is .70 above the rear end ratio which is much more engine friendly on the highway. A later T5 might be more to your liking as they have a wide range of gears plus an overdrive. Fred
