6 members (TUTS 59, Bill Hanlon, Shade Baby, Rusty Rod, Dragracefan, 1955 1 Series), 122 guests, and 2 robots.
Topics128,157
Posts1,056,887
Members48,458
V
V Offline
We got the repop lower radiator hose that all the big parts suppliers are selling and it just looks like the metal elbow is exhaust tubing bent on an exhaust pipe bender. Is this the way they were done originally because it doesn't line up very well with the water pump inlet? Also the bend is so big and collapses the tubing such that you only end up with small sections of perfectly round tubing on which to put the original style clamps included in the kit. Then there's the problem of the water pump inlet being bigger than diameter then the tubing which is 1 1/2". It's almost impossible to get this all to seal up with the original style clamps. Seems like GM would have used a better formed elbow than this. Does anyone offer a better original style set-up than this?
Do not know what you have tried but check this out>
Lower Hose
Harold
Harold
