5 members (NJC, 32Fordpuchoptop, 48jim1ton, BillyDon, Jman), 94 guests, and 3 robots.
Topics128,042
Posts1,055,601
#1102823 05/15/2015 9:31 AM
I bought a 12 volt heater switch from chevs of the 40's and wired it. It's a 3 position switch and the heater runs fine. However I was under the dash and it looks like the rheostat is glowing hot. I know I'm reducing voltage to 6 volts for the heater but not sure this is how it should work. Don't need a fire at this stage!
The amprage goes UP as the voltage goes DOWN...so using a 12 volt switch on a 6 volt motor is a bad thing. Your new switch may be rated at 15 amps and your 6v motor may be pulling 20 amps or more which would be a fire hazard.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
So should I get a 6 volt switch our keep the 12 volt and put a resistor in between the switch and heater?
Riding in the Passing Lane
If you are running a 6 volt battery & 6 volt heater you need a 6 volt heater switch. The switches with built in rheostat & resisters will get but not glow like that.
1972 Chevy c10 Cheyenne Super
