3 members (Hotrod Lincoln, Steve_H, 1 invisible), 139 guests, and 3 robots.
Topics128,149
Posts1,056,814
Members48,454
Moderated
Moderated
Greetings, can anyone recommend a clutch manufacturer for a clutch kit to 1956 235. This will be a daily driver with a T5 behind it and the stock 3.90 rear end. TIA
Drew
Drew's 1956 3100 235
The major FLAPS offer quality replacements. I have no idea who makes them.
That or..if you have a truck clutch & brake shop around the area
they can check out your plate and resurface it and rebuild our
disk for about the same price you'll pay at your FLAPS.
Here's the job one in the city did rebuilding my old disc
and pressure plate.
http://www.pbase.com/dennygraham/image/128167927
Don't know how far north you are, but Sacramento has a few
such as this:
http://www.capitol-clutch.com/
Usually those making a living as commercial truckers won't
put up with the same carp that AutoZone or NAPA tries
selling the public. They demand reliable products.
dg
Denny G
Sandwich, IL
The clutch disc will have to match the splines on the input shaft of the T5 transmission. The flywheel and pressure plate can be what is stock to the truck. (Just in case you didn't already know.)
Carl
I got mine from clutch exchange service, very pleased. Call them at 770 943 2666 and tell them what you have
