0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#110254 04/08/2004 6:11 PM
I
I Offline
First dont laugh.
Second.
I bought a black and decker orbital/mouse/ whatever multipurpose sander for home projects.
I know we discussed this a while ago but I have a slight twist.
It came with a foam pad you can attach sand paper to.
Is this a bad attachement for use on my truck?
I was thinking maybe it would be a neat idea to use the foam on the rounded portions.
any comment?
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#110255 04/09/2004 12:24 AM
I have a Bosch VSO (variable speed, orbital) electric soft start sander that I really like, and it has three differant hook&loop pads, stiff, medium, and soft. I tried all the pads when I was stripping when I did my jeep (I hooked the sander up to vacuum and used a face mask), and I used the soft pads between filler and primer and it worked pretty well but you should use blocks or a long inline sander when doing the rough sanding on filler to keep the contours flat.
It is a bit dangerous to use an electric sander when you are sanding new paint due to the fumes, and you shouldn't use it to wet sand at all. Make sure you plug it into a GFI.
As with any sander you should always keep it moving and stop and start it while it is in contact with the surface
Paint & Body Shop moderator
#110256 04/09/2004 12:51 AM
I
I Offline
I would like to use it to strip before etch priming.
