1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#1102312 05/12/2015 8:35 PM
Hoping this does not sound dumb, but I am not very mechanically inclined and have been told by a local (somewhat) mechanic that I need a new starter. My truck is a '54 3600 with the original 235 engine. I am wondering where you would recommend ordering one. I believe from looking at the truck's documentation the OEM part is Delco 1107108.
I appreciate the help because I start to get confused when I look on-line and see several choices (again, not very mechanically inclined).
Today is the best day of my life!!!
Check your area for an Auto Electric Company and take your starter to them. They can bench test and tell you if and what your problem may be. They can also rebuild your starter (and generator if needed) for a lot less than buying a new one.
Harold
Harold
I would recommend having yours rebuilt locally. I don't know how far from Mineral Wells you are but I know a good shop there. Also Stovebolter Kennethw has a shop in Ellis County.
[email protected]
Sir Searchalot
Sir Searchalot
Kennethw is a good man to deal with.
Thank you very much for the info! Unfortunately, Mineral Wells is 2.5 hours and Ellis county is about 3.5. I will write to Kennethw and see what we can arrange.
Again, thank you very much for the help.
you could also try napa auto parts if you have one in your town.
Sir Searchalot
Sir Searchalot
Napa does have very good sale prices on that starter.(6V) They are all rebuilt so everybody charges core charge. I believe Napa will ship or deliver! if you are not too far.
NAPA is in next town 30 miles away. Ordered from them and got next day! Thanks for all the help. Now, just need to find time to install starter and hopefully, get Carmen running.
Thank y'all very much. Got a starter at Napa. Also found out I needed new fuel pump and water pump so also got those at NAPA. Finally had them installed and truck is up and running.
smile
