0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
Just about to finish up my first door. A few questions.
1. The window channel kit included "side window rubber bumpers" marked with Jim Carter p/n W1230. Where do they go?
2. Does some sort of windlace or weather seal attach under the inside door skin and window trim?
3. Attached to the front and rear sides of the door frame are 2 horizontal braces. When I originally disassembled the door,there were some rubber pieces between these braces and the outer skin. Is there supposed to be something there? If so, what are others using for this?
Bob
BobS46
Bob, I'll give this one a shot.
1. Not sure about the rubber bumpers, they might go inside the door where the window comes to rest in the down position.
2. There is no windlace or anything attached to the doors. The windlace goes around the door frame and there is a rubber seal along the lower part of the door opening.
3. Those pieces of rubber are to prevent the door skin from rattling against the horizontal braces. I covered the entire inside of my doors with sound deadening material so I didn't use them.
Hope this helps
George
(46forme)
THanks,
That did help - confirms what I had suspected.
BobS46
Bob,
This photo may help.
Harold
Window Bumper
Photo of Window Door Glass Channel
Door Glass Channel
Photo of seal between door and lower floor
Seal
Harold
Moderated by  ndkid275, Phak1
