3 members (Bill Marlow, tclederman, 52Carl), 54 guests, and 3 robots.
Topics128,090
Posts1,056,028
Members48,432
#1102164 05/12/2015 12:03 AM
So I picked up a Harrison 47 heater for my 47 3600 ad. I knew it was missing a wire coming out of the motor, but it was cheap. Anybody got a schematic or photos of the insides of one? Hard to tell where I should solder at.....thanks. Marko
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
I think my motor has one wire coming out and the other connection is through the case.
1951 1 Ton Completed
This is the original Deluxe that was installed in the truck
when it was delivered in '50, according to the original owner.
Back about 6 or 7 years ago I turned the commutator and
installed new brushes in the original motor. as you can
see, the original motor had a ground wire also and was
not simply grounded thru the case.
http://www.pbase.com/dennygraham/image/121512986/large
There are also some pictures of the internals Marko, look
thru them and maybe you can figure out where your wires
are missing.
DG
Denny G
Sandwich, IL
