0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 33 | I'm getting ready to change out a leaky rear differential carrier gasket and leaky pinion seal on my '59 Apache. I'm planning on removing the vent tube and giving it a good cleaning while I'm at it. I've heard a clogged vent tube can sometimes cause gaskets/seals to blow out. I'm wondering if there are any additional tips or lessons learned that I might need to be aware of before I get started? Any and all info is always appreciated. Thanks! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy F*C, could you tell us the size of the truck and how many bolts hold the carrier to the axle housing please? | | | | | Joined: Mar 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 33 | Sure, it's a 1/2 ton, 10 bolt pattern. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy F*C, the carrier gasket is Fel-Pro p/n RDS 4305 the cover gasket is p/n RDS 4304. The seal is C/R 17727 the Speedi-Sleeve C/R p/n is 99170, hope that helps. | | | | | Joined: Mar 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 33 | I was wondering about the Speedi-Sleeve. Now I don't have to check it up. Thanks for the info. | | |
