| | | Forums66 Topics128,051 Posts1,055,762 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 16 New Guy | | New Guy Joined: Mar 2015 Posts: 16 | I need some help figuring out what rear axle I have. I'd like to know what sort of load it is rated for. This is 57 Task Force with a 3/4 VIN, but with the wheelbase lengthened a little by cutting and reattaching the frame. So for all I know, the whole rear end could be different. But the frame rails are the same size and everything looks like it matches.
I know so little about trucks, I'm not sure what to look for. Makes googling for information challenging.
With one set of dually wheels off the ground, and one stopped, I spun the wheel 10 times, the driveshaft moved 23 to 24 times. This surprised me as I was expecting a ratio closer to 4.5-7 for this truck. Is a gear swap doable/possible such that this could be the original axle with a different set of gears? My reading on here didn't seem to indicate that any were available. Am I trying to determine the ratio incorrectly?
It's got two sets of springs. It looks like a set of 10 leafs, with an additional overload set above it. 5 or 6 springs on it, I need to recount.
After some scrapping, brushing, cleaning there is a number on top of the axle housing that says CD1129.
Anything else I can check to help identify this?
Thanks, JFS III
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | According to the GM Heritage Resto Pack site, CD1129 comes up as a 3600 axle, 4.57 gears, with RPO 285 Dual Wheels. It should have 7.00-17.5 tires on it. The 10 leaf springs were a factory option, the overloads are probably aftermarket.
Bill Burmeister | | | | | Joined: Mar 2015 Posts: 16 New Guy | | New Guy Joined: Mar 2015 Posts: 16 | That makes sense to me, and is a ratio I was expecting. But I was thrown when I spun the tire and got a much different number of revolutions on the driveshaft. I would expect that if I turned the wheel 10 times, I should see just shy of 46 revolutions in the driveshaft.
Am I not understanding something somewhere? I counted roughly half that.
Edit: Nevermind... There's a factor of 2 in there, even with the opposite wheel blocked according to sources online.
