Saw mostly STOCK glass/installations on a forum search. This is a hot rod, plan to use two piece glass w/NO divider, just silicone. I have NO window frames or hinge and dont PLAN on a swing out window.
1 where can I buy a gasket for this? See some generics on ebay w/lock strips that look OK.
2 suggestions on glass, locals can cut it but must make a pattern.
3 Have the rear glass but no rubber, again, where to buy
4 I need ONE side glass, best to order that or have it cut locally?
