1 members (Otto Skorzeny), 95 guests, and 1 robot.
Topics128,034
Posts1,055,552
#1101508 05/08/2015 5:58 AM
Fox
Offline
About to put my head on and I have a couple questions.
1. I noticed on the driver side near the front of block that the gasket blocks 2 coolant passages. (Not the steam holes) Why? The old gasket is the same. Curious as to why these 2 holes to the head(848) from the block would be blocked off.
2. Should I use a sealant on the gasket? It doesn't say whether to or not. It is a fibrous one with steel/copper rings.
Head and block are flat, clean and ready to go.
Thanks bolters.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
216s have the same deal going on. Weird.
Fox
Offline
Still wondering if I need to seal this gasket and why these two holes are blocked.
http://s1372.photobucket.com/user/foxj12/library/?view=recent&page=1
It is the top left photo. Where I'm pointing shows how the gasket blocks off that hole and the other hole two cylinders to the right.
Does this gasket need a sealer?
Thanks fellas!
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Gas Pumper
Gas Pumper
I hope someone who really knows answers, but I would be very suspicious about blocking any holes with a gasket. With my 235 being at the machine shop and that step is coming soon, I too would be interested in an answer.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Do not use sealer on composite head gaskets. Steel or copper shim gaskets, yes, but not on a layered type. If the holes are blocked, there's probably a good reason. One of my students opened up some head gasket holes in a small block Ford V8 that he thought the factory "forgot" and ended up with an instant overheat. It turns out the gasket was made to work interchangeably from one cylinder bank to the other by observing the "top" marking, and the holes in the front of the head were supposed to be blocked so coolant would flow toward the rear of the engine. Don't second-guess the people who make the gaskets.
Fox
Offline
Thanks Jerry!
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
I'd put a little Teflon paste sealer on the headbolt threads to prevent any seepage.
1946 1/2-Ton Chevy
235/261 are blind hole head bolt engines. Only oil on threads is needed.
My Blog
Fox
Offline
The 216 head bolts thread all the way through?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
V
V Offline
I'm unsure if the 216's head bolts extending into wator/oil galleries but all I used was oil on the threads of my 216's head bolts and so far no problems/leaks with approx. 10k miles on it.
Now my 216 pizzes oil out other locations but not through the head bolts grin
re. head gasket sealers, I've never used any type of sealer on a head gasket. From small air cooled to large diesels, I use the proper head gasket, clean "true" surfaces and the proper torque technique on oiled head bolts.
Dave
I just checked and a 216 is also a blind head bolt hole block.
My Blog
