3 members (stlcardinalsguy, dunfire, Otto Skorzeny), 110 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#1101590 05/08/2015 7:03 PM
Just picked this up, 1955 3800 9ft box.
http://i203.photobucket.com/albums/aa152/jeepnski/3800/IMAG1486_zpsjtvtllua.jpg
my plans change daily, but i'm trying to decide between cutting up the stock frame or selling the entire complete rolling chassis with motor. the frame is SOLID, and most of the suspension/running gear even looks perfectly usable, but is there enough of a market for something like this? if i can only get just over scrap value for it, i might as well just use what i have ... but if someone out there restoring a truck could really use this, i'd rather pass it along to them.
More pix in Photobucket
If this is intended to be a parts for sale ad please post in the swap meet section.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=cfrm&c=3
If you are planning to keep and drive the truck don't mention seling it in the general forum sections.
Grigg
6DoF #1101612 05/08/2015 10:03 PM
Authorized Pest
Authorized Pest
Yes, once you decide about selling or keeping, let us know and we can move it over to the Swap Meet.
Peg
~ Peggy M
1949 Chevrolet 3804
6DoF #1101641 05/09/2015 12:54 AM
No parts to sell and no price to post on them, i came here to start a discussion. Discussed why I didn't post in classifieds. Thanx for the help by adding your insightful comments.
... Fail
To answer your one question there is probably not much of a market for 1 ton running gear without a good truck around it. Its the body that most folks need.
What else did you want to discuss or know about that may help you decide what to do?
•1952 Chevrolet 3800 pickup
---All pictures---
The truck looks like a good candidate for restoration. Looks to be fairly complete.
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
6DoF #1102037 05/11/2015 12:59 PM
it is a 100% complete truck that i do plan to fix up and drive the doors off it. i don't know why, it's just killing me to think about chopping up this frame for modern suspension ... but it's a solid frame and there's no better place to start building from. i think i just need to get over it and do it though.
after running some numbers, it looks like this frame will be more heavy then i need/want to run. and this i'm sure is exactly why there's really no market for em.
First thing to decide is what is end goal use for the truck and your budget. Is it a daily driver with light duty or will it be used to haul/tow heavy loads. Unless you are a good fabricator with the skills needed putting a "new" frame under the truck is not as easy as it sounds and takes time. Buying a chassis aftermarket gets pricey. I believe it is far easier to keep existing frame and add driveline parts to fit your needs. Good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Yuppers I agree, if you wanna close to home daily driver from a money standpoint, fix what is broken and drive it the way it is....
Not sure what you are looking at in the end.....but these things can suck major holes in your wallet in a real hurry...the less you change the less money you will spend on it...
I think it looks cool just the way they it is...
my 2 cents
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
6DoF #1104107 05/22/2015 11:02 AM
24601
Agree with Bourbon and MikeC -- There's a few of us with AD 1-Tons who drive them a fair amount and find them to be decent drivers in stock configuration.
I echo the sentiments above -- get it running safely and reliably the way it is and see how you like it (give it a fair shake) before you spend a lot of money on upgrades. You may find (as most of us do) that it is just fine (and a lot of fun) the way it is.
One upgrade you can consider that's fairly cheap and easy to perform, is switching out the rear axle center section to get a little bit higher gearing (for a little more speed in traffic). Check out our tech tips for that one. Make sure your brakes work, first!
Good luck!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderated by  Dusty53
