| | | Forums66 Topics128,077 Posts1,056,281 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 17 New Guy | | New Guy Joined: Nov 2014 Posts: 17 | Just picked this up, 1955 3800 9ft box. http://i203.photobucket.com/albums/aa152/jeepnski/3800/IMAG1486_zpsjtvtllua.jpgmy plans change daily, but i'm trying to decide between cutting up the stock frame or selling the entire complete rolling chassis with motor. the frame is SOLID, and most of the suspension/running gear even looks perfectly usable, but is there enough of a market for something like this? if i can only get just over scrap value for it, i might as well just use what i have ... but if someone out there restoring a truck could really use this, i'd rather pass it along to them. More pix in Photobucket | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If this is intended to be a parts for sale ad please post in the swap meet section. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=cfrm&c=3If you are planning to keep and drive the truck don't mention seling it in the general forum sections. Thanks, Grigg | | | | | Joined: Apr 2004 Posts: 5,081 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,081 | Yes, once you decide about selling or keeping, let us know and we can move it over to the Swap Meet.
Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Nov 2014 Posts: 17 New Guy | | New Guy Joined: Nov 2014 Posts: 17 | No parts to sell and no price to post on them, i came here to start a discussion. Discussed why I didn't post in classifieds. Thanx for the help by adding your insightful comments.
... Fail | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | To answer your one question there is probably not much of a market for 1 ton running gear without a good truck around it. Its the body that most folks need.
What else did you want to discuss or know about that may help you decide what to do? | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | The truck looks like a good candidate for restoration. Looks to be fairly complete.
Mark | | | | | Joined: Nov 2014 Posts: 17 New Guy | | New Guy Joined: Nov 2014 Posts: 17 | it is a 100% complete truck that i do plan to fix up and drive the doors off it. i don't know why, it's just killing me to think about chopping up this frame for modern suspension ... but it's a solid frame and there's no better place to start building from. i think i just need to get over it and do it though. | | | | | Joined: Nov 2014 Posts: 17 New Guy | | New Guy Joined: Nov 2014 Posts: 17 | after running some numbers, it looks like this frame will be more heavy then i need/want to run. and this i'm sure is exactly why there's really no market for em. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | First thing to decide is what is end goal use for the truck and your budget. Is it a daily driver with light duty or will it be used to haul/tow heavy loads. Unless you are a good fabricator with the skills needed putting a "new" frame under the truck is not as easy as it sounds and takes time. Buying a chassis aftermarket gets pricey. I believe it is far easier to keep existing frame and add driveline parts to fit your needs. Good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Yuppers I agree, if you wanna close to home daily driver from a money standpoint, fix what is broken and drive it the way it is....
Not sure what you are looking at in the end.....but these things can suck major holes in your wallet in a real hurry...the less you change the less money you will spend on it...
I think it looks cool just the way they it is...
my 2 cents
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Agree with Bourbon and MikeC -- There's a few of us with AD 1-Tons who drive them a fair amount and find them to be decent drivers in stock configuration.
I echo the sentiments above -- get it running safely and reliably the way it is and see how you like it (give it a fair shake) before you spend a lot of money on upgrades. You may find (as most of us do) that it is just fine (and a lot of fun) the way it is.
One upgrade you can consider that's fairly cheap and easy to perform, is switching out the rear axle center section to get a little bit higher gearing (for a little more speed in traffic). Check out our tech tips for that one. Make sure your brakes work, first!
Good luck! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
