0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1101685 05/09/2015 6:26 AM
On a 37 half ton truck right hand drive should the vent lever bolt on the right or the left
Ie closer or furthet away from the steering column
I,m thinking that my query above might not be clear and Im hoping that someone with 37 1/2 ton can help
The cowl vent has two sets of holes drilled to accept the cowl vent lever
This seems typical of the truck design which accommodates left or right hand drive models depending on what country your from
As there are two sets of pre drilled holes in the cowl vent to accept the cowl vent lever which set are correct, closer too the steering column or closer to the glovebox?
Den99 #1101842 05/10/2015 11:24 AM
back yard wrench turner
Here is a photo taken by AChipmunk
Looks to be on the left, nearer the driver.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Moderated by  ndkid275, Phak1
