8 members (Donf, Goach2, Otto Skorzeny, cmayna, Joe H, Wally / Montana, Gdads51, 1 invisible), 89 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
#1101486 05/08/2015 3:53 AM
Can someone give me the SKF or Timken part number for front wheel roller bearings on my 53 3100.
I'm not sure there is a SKF or Timken number. All the front wheel tapered rollers where cheap Chinese knock offs with a number that doesn't interchange with anything.
Are you wanting a number for tapered roller bearing sets or for the ball bearing sets?
The ball bearing would have been original.
B01 for outer bearing B52 inner both made byNational National Seal is R1502EL
Timken also shows B45 as outer roller bearing
All those should be roller bearing, not tapered,
I was looking for tapered roller bearings but if they are cheap Chinese junk Ill stay with the ball bearings. Thanks for the response.
