2 members (pauld, Otto Skorzeny), 131 guests, and 2 robots.
Topics128,201
Posts1,057,281
Members48,467
I have two transmissions that I was going to combine and rebuild into one good one. Once they were both fully apart, I noticed some things that I don't know.
One case has an 8 GM 591615 (the one from my truck) and the other has 6 GM 591615 (extra trans).
Not sure if there is a significance of the first number when deciding which case to use.
The mainsheet in the 8 GM 591615 is stamped, WT242-2C. My truck is a '51 and I think the '51 trans has a WT242-2B mainshaft.
I guess what I'm asking is; is there a problem with mixing parts and or case?
Does anyone have the specs for the transmission components so I can hunt for the correct ones?
Any help from Bolters would be great!
The complete transmission would interchange. The preceding numbers are not referenced in the Hollander and that is about the only book that will tell you casting numbers. They used a 3/4" and a 23/32 shaft. I think the B is the small shaft and the C is the larger of the shaft. .7500 compared to .71875 should be easy to measure with a caliper. If you do have 2 different shaft sizes. you have a problem already with the top shaft. Your 53 may have the synchro with 4 dogs on it compared to just 2 dogs on the 51 model.
