| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Can someone give me the SKF or Timken part number for front wheel roller bearings on my 53 3100. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I'm not sure there is a SKF or Timken number. All the front wheel tapered rollers where cheap Chinese knock offs with a number that doesn't interchange with anything. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Are you wanting a number for tapered roller bearing sets or for the ball bearing sets?
The ball bearing would have been original.
B01 for outer bearing B52 inner both made byNational National Seal is R1502EL
Timken also shows B45 as outer roller bearing
All those should be roller bearing, not tapered,
| | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | I was looking for tapered roller bearings but if they are cheap Chinese junk Ill stay with the ball bearings. Thanks for the response. | | |
