2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#1101465 05/08/2015 2:20 AM
Will 6 hole buds from other makes of trucks work on Chevys?I have a tractor with a 1959 Chevy rearend that i use and right now i am use wheels from a 1953 army trailer. will ford and dodge wheels interchange?
3B Offline
Hy Old Doug, as far as I know six bolt Budd wheels all have the same bolt pattern and should interchange between marques, the only caution I would add is to make sure the center hole is the correct size or larger for your intended application, hope that helps.
