| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | I have all of the split clamp rings removed and the side rings, but I'm having quite the time removing the tire from the rim on the other side. Does anyone have a special lube ( shop manual mentions neutral vegetable soap to mount the tires) or just spray with WD40 and let soak? Original rubber is still pretty good so I don't want to cut them off perfect for shows not for cruising.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They still sell rubber lube at most parts stores, but you may have to ask for the commercial sales person to get it. Usually comes in a gallon jug, either straight or premix.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A strong soap solution works good. Delute some liquid soap about 2 to 1 with water. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | I used some of my wife's Murphys Oil Soap ( Hardwood floor cleaner) and off they came, perfect now off to the sand blaster.
