| | | Forums66 Topics128,283 Posts1,058,521 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 42 | Can some one tell me if the doors on a 46 1/2 ton truck be adjusted from the front to the back? | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | There is not any slotted movement. Any adjusting would have to come from a shim or tweaking the hinge.
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Randy is correct as there is no adjustment as per say.....but you can massage with a 2x4 up, down in and out to make fit better. There is no set way to complete that other than trial and error. Are your pins new? Can you drill and add bushings? Is the door square? Or been reworked? Ability, experience and knowledge all factor in. Being a little stubborn will help. Have fun and good luck Dan | | | | | Joined: Oct 2012 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 42 | It sounds like to make them fit I will have to put shims behind the hinges as Randy says because the gap is grater in the back of door than in the front. BTW I'm 70 years old and this is my first attempt at doing a resto-mod or far as that goes I havent worked on cars or trucks very much at all but I really enjoy doing this. Thanks for the help Don | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Don, I have a PDF of a few pages from the 46 GMC manual which shows among other things how to adjust the doors. I used the info on my 46 Chevy it worked just find. Shoot me an email and I will send you the PDF. George [email protected] | | |
