| | | Forums66 Topics128,088 Posts1,056,413 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 21 New Guy | | New Guy Joined: Apr 2015 Posts: 21 | I cannot crank this truck. I am going nuts. If I switch the plug wires, it pops and spits like crazy, but when I set them in the correct order, I get nothing. I have replaced the coil, plugs, wires, rotor, cap, points, and even tried ether. I have gone through the timing routine too many times to count now. Every mechanic I know has been here to show me how it is done, and gone home with a sad face. Anyone got any ideas? I think I am going to pull down the road next.
It has a P 7R Tillotson which has a brass handled needle valve that looks out of place. I took the carb down to its components (it was as clean as a new whistle). Fuel pump works (clean it daily). Spark is present, no air restriction, and I had a puddle of gas in the bottom of the intake when I took the carb off.
ARRG!!!
Jim | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | sounds like you could have some stuck valves
| | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | What's the compression pressure? If it's got gas. spark, and compression, it's almost got to be a spark timing issue. Check your private messages. Jerry
| | | | | Joined: Apr 2015 Posts: 21 New Guy | | New Guy Joined: Apr 2015 Posts: 21 | It was out of gas. Stupid me. I am so embarrassed.
Jim | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Apr 2015 Posts: 21 New Guy | | New Guy Joined: Apr 2015 Posts: 21 | | | |
