Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#110112 01/26/2005 9:06 PM
Anonymous
Unregistered
Anonymous
Unregistered
Is there a supplier for a patch panel to block off the fresh air louvers on the right side cowl?
I have decided I will not be needing these.
#110113 01/26/2005 9:51 PM
I
I Offline
I just saw them either in a brother or chevy dudty catalog.
I will check later and report.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#110114 01/26/2005 10:46 PM
Similar question from the opposite viewpoint. Does anyone know of supplier that has the driver's cowl patch panel for '49/50 with the vent frame in place?
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#110115 01/29/2005 7:32 PM
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#110116 02/02/2005 5:33 PM
I
I Offline
Hmmmmmm.
I know I saw them... They do exist!
Maybe it wasn't on those two sites though.
I am now on a mission. I was thinkin about patching mine too.
I will post the results of my search.
#110117 02/04/2005 9:50 PM
Do all AD's even have vents? If not couldn't you just buy a different year panel?
#110118 02/08/2005 5:15 AM
On the full cowl patch panel, does it have the back edge that goes along the door opening on it?
#110119 02/08/2005 5:22 PM
The right-hand louvers for the fresh-air heater and the top-of-cowl pop-up vent are there on all AD years. The driver's side pop-out vent was eliminated when vent windows were added to the doors.
1954 GMC De Luxe COE
#110120 02/08/2005 6:50 PM
OooOOOooo. While you all are talking about cowl vents, anyone able to get me a picture that will go with a Tech Tip on Cowl Vent Seal replacements that Woogeroo had done. It could really use some pictures.
(Send them to me at [email protected]). I doubt I'll remember to look back here.
Peggy
~ One of many.
#110121 10/31/2005 5:21 PM
Hey Nifty 50,
Did you have any luck finding a driver's side outside cowl patch panel with the side cowl vent frame in place? I am trying to find one for a '50.
#110122 11/01/2005 6:35 AM
Jon, No I didn't and I do not believe that they exist. I ended up biting the bullet and cutting out my bent up frame, straightening it as best as possible, cutting a hole in full patch panel and welding frame into it. I have now spent the last several weekends trying to get the panel lined up with fender, hood, door, and vent door. Not fun. If I had to do it over, I would attempt to cut around the vent frame and leave as much of the area under the side of the hood as possible. Even if this meaned having to work the panel and frame in place. (I had the standard damage from a sprung door and a bad slide hammer and bondo repair.) Learned the hard way what I had been told repeatedly and didn't really listen, "only cut out what you absolutely need to." Good luck,
Steve O
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
#110123 11/02/2005 1:47 PM
Peggy, I have my cowl vent out of the truck and I could send you some pictures. What sort of pictures do you need?
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#110124 11/02/2005 2:18 PM
cujo --
You are asking me this part? Can you take a look at Woogeroo\'s Cowl Vent Tech Tip and see if any *angle* or *item* will work.
Even if you aren't able to show the same thing as what Woogeroo is explaining (replacing the seals), even just having a picture of the cowl vent may help some folks in knowing what we are talking about in the tech tip.
Wow ... thanks! This is really an old one!
grin
Peg
~ One of many.
#110125 11/02/2005 10:12 PM
Peggy,Cujo and all; I think Woogeroo,s Tech tip has to do with the 60/66 style plenum vent seals.
Totally different design and style on the AD,s.Regards
Steve sr.
#110126 11/02/2005 10:52 PM
Thanks. I wondered if it was particular to that year.
I know what a cow is ....
Not sure about a cowl
:confused:
Peg
~ One of many.
