2 members (RLB, qside),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | I have taken the wood out of my panel and done some measurments. The difference between the inside and the wood all squeezed together is only 1 inch. Now if I go by the advice given for the pickup beds then this will be to tight. So do I make the new floor to the old dimensions or heed the advice of other posts? This would mean making the boards a little undersized to now? Any thoughts or does someone have the actual dimensions out there? There is 4 groove splits and the outside board over laps the first inside board similar to shiplap. | | |
