1 members (Goach2),
118
Mod | | | Forums66 Topics128,185 Posts1,057,274 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 137 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 137 | my 59 napco carryall needs another roof ! i was told it unbolts along the sides and has to be cut in front windshield posts to remove ? what about the back corners next to rear doors ?? need any cutting there ? anybody confirm this ?? what do you think it weighs ? how many to lift it off ?? thanks mike think i found one/but just in case still looking for one ! a panel truck is the same !? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Panel truck is the same. All needs cut. Don't know of any bolts. The sides are "gas or arc" welded to top with probable spot welds at "A" pillar and bulkheads. Where is problem? Drip rails? windshield surround? why whole roof? Red58, et al, can confirm or suggest options. Is this a rust repair or accident repair? Sounds like you have already made your decision but try to see if there is a way to repair just sections with your donor. The weight will be approx. 90-110 lbs., two guys can lift.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I replaced the entire cowl with door and windshield frames from a donor pick up. But it is a 37. Had the top off at the same time. Cut top at b pillars drilled out spot welds across wind shield and top of doors. The rest is bolted. I don't know that yours is the same
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | I sent you a PM. First attempt on this site, so I hope it went correctly. | | | | | Joined: Jul 2012 Posts: 82 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 82 | Did the same on my 51. I guess the technique remains the same? If so you can see in my gallery pics. Good luck | | |
