7 members (Gdads51, Hanks custodian, Steelonsteel, TUTS 59, Mike Burns, Wayne67vert, 1 invisible), 86 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#1100750 05/04/2015 1:26 AM
1950 3100 chevy all new part's, spring, line's,wheel cylinder master cylinder.Left rear lock up after driving,about ten mile's .But not all the time. The rim warm to touch. A little drag on wheel from brake,no matter how you adjust them left side only axle not warm .If you break line it release pressure Then brake return.Have on jack stand you can punp brake seen ok.
What procedure did you use to adjust the brake shoes? The procedure in the Shop Manual?
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0513.htm
Sounds like you have a severe obstruction between the brass T and the wheel cylinder preventing the fluid from heading in the direction of the master cylinder when the pedal is released. Remove that section of brake line and check to see if it is obstructed.
Carl
Found out why break's lock up.When i ran new brake line didn't follow frame Was about 4.5 inch from exhaust. To close brake fluid would heat up after 10 to 15 miles.Use couple license plate to see if i was right,it work drove 20 miles or so seem find.will do it right second time
Where I live, brake lines not tucked up into the frame would not pass a safety check. There is a reason why they put them there.
1951 1 Ton Completed
