4 members (1955 1 Series, Barney1951, Otto Skorzeny, 1 invisible), 44 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#1100557 05/02/2015 6:38 PM
I have 57 235 with an 848 head. Is a 61 235 head a direct fit replacement or do l need to make modifications. Thinking about rebuilding the 61 head an installing it on the 57 engine
thrs50 #1100586 05/02/2015 10:48 PM
Gas Pumper
Gas Pumper
They are the same. If the number is 848, thats the last three of the actual casting (part) number. As long as you are installing it on a 235 engine, you are good to go. Do not mix and match the rocker assembly. If the oil tubes across the rockers are worn on one, do not just change the tubes, change everything at once.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #1100671 05/03/2015 11:42 AM
Thanks Dave and by the way your 1959 235 project is great
thrs50 #1104348 05/23/2015 2:20 PM
Deve 57 block has a oil line in the side where the lifters are the 61 doesn't. Should I use the head bolt with the oil slot from the 61 or use the bolt w/o from the 57. Also is there any other things I should do. Trying to get it back together this weekend
thrs50 #1104375 05/23/2015 4:19 PM
A 1957 235 should not need any drilled or slotted head bolts as long as all the oil passages are clean.
My Blog
