| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 34 | My 1941 1/2 ton has two holes in the area just above the center of the rear wheel well, each side. Looks like there were may have been some type of reflector in that location.
I've looked a many photo's of 41's, and have not found an example.
What belongs there?
Thanks, Ed | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | My guess is they were used to attach the fender stiffener. If so, on the bed side there will be one or two additional holes. My memory is foggy at the moment and my fenders are not readily available. | | | | | Joined: Mar 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 34 | Thanks for the response. I believe you are correct. I assumed there was only one stiffener per side, seems there were two. | | |
