2 members (Peggy M, Gdads51), 106 guests, and 3 robots.
Topics128,169
Posts1,057,043
Members48,458
Hi, I am a new owner of a '46 3/4 ton with a stock 216 and 4 speed trans. I have other vintage vehicles but I'm new to the chevy in line six. In other cars I use Valvoline VR-1 racing Oil 10W30. I like it for the elevated level of zinc to protect the engine. Yes, I know that discussing engine oil can be polarizing but I'd like to hear what you guys think is the optimum engine oil for this old 216. Also interested in what what you recommend for transmission and differential lube. Thanks!
1946 Chevy 3600 Pickup
1948 Chevy Sport Coupe Country Club
1963 Corvair Monza Spyder Convertible
V
V Offline
A lot depends upon the condition of your 216.
Chevy spec'ed straight 20w back when it was new and that was good for most all temp ranges.
A lot of folks run either a 5w30 or 10w30 on a newly rebuilt engine. Some run a straight 30w, and some run 15w40. On high mileage engines it's not unusual to run 20w50.
The bottomend of my 49 216 is of unknown mileage but based on the original odometer I guesstimate around 100k miles on it (the head was rebuilt approx. 10k miles ago) so I run 15w40. I'm avg'ing approx. 12psi at speed and perhaps 5psi at idle when warm. I tried 20w50 to see if the pressure would pickup some and it didn't and the engine was louder w/10w30. So I settled on 15w40 which also happens to be less expensive, which works out good for my leaking rear main seal too.
You may have to experiment around to find the best grade.
re.tranny and rearend lube. I use an 80w90 GL4/GL5 rated lube for my tranny and rear. Both run quiet and seem to work fine on it.
Good luck
Dave
Ex Hall Monitor
Ex Hall Monitor
Oils are so much better now than back then that any quality modern 10W30 will work just fine unless your engine is worn to the point that the pistons are trying to swap holes. grin
