I am rebuilding the 270 to install in my '53 1/2 ton. The engine heads are the same so wondering if the cams are as well.
On another subject my truck has the hydra-matic trans which uses the Zenith carb with auto choke. The 270 had a manual choke Zenith. I recall from a previous forum discussion that Zenith carbs came with different venturies. Without dis-assembling the two, does anyone have specs on the two carbs?
