| | | Forums66 Topics128,195 Posts1,057,377 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 81 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 81 | Assembling my 283ci and do not have a good picture of what was in this passage when I disassembled. Oil pressure fitting is in front of block - is this just an alternative location that needs to be sealed? If so, what type of fitting should be used?
gobolt
| | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Oil pressure fitting should in back of block by dist. Fitting in front of block should have a plug in it. | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | The pressure fitting at the front was a leftover from the 1955 265, which did not have a full flow oil filter. The input line to the bypass filter attached there. In 56, the filter canister mount was incorporated in the driver's side rear of the block and the front oil port was plugged. Eventually, that port was not drilled and tapped. I used to drill and tap that hole for a pressure warning light on the race engines, since it's at the very end of the pressurized oil passages. We set the idiot light switch at 20 PSI so the driver had time to shut down before serious damage in case of an oil pump failure, etc. Jerry
