0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I'm finally ready to buy tires for my '42 1/2 ton. The rims I'm using are 7.00x16". I want to go with a radial for better ride but was shocked at Coker's prices. I want the tire to have a bias ply original look to it. Any recommendations appreciated. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Try Diamondback tires..........I bought my tires there...however none of those tires are cheap.. Dan | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Unfortunately, tire prices have really gotten out of hand lately, even for regular modern radials.
Bill Burmeister | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Try the automotive flea markets. I purchased a set of 6 tires (215/85R16) Michelins for $100, put over 5000 miles on them already. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I would be very careful buying used tires. Unless they came off a vehicle you either used personal or at least know how it was used, you really don't know what you're getting. Even if they do look good, you'll want to check the codes to make sure how old they are. It's getting to where many shops will not install tires over 4 years old due to liabilities, and many will not mount or sell used tires at all. I'm not saying you can't find a good deal, just saying to use caution.
