2 members (Peggy M, MTD91),
148
0
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Has anyone here had any luck finding aftermarket replacements for these? I've seen a few on Ebay but they appeared to be bent & rusted trash.
Found them in high dollar stainless for '37-'38 trucks but they don't know whether they will fit war years trucks or not. Nothing else I have found online so far. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Is this what you are asking about? Support Rod Harold
Harold Is a restoration ever finished? | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Exactly Harold...but minus the "issues" that one has. The threaded ends are mangled and rusted away. I've seen a few on Ebay but most were in similar condition and was hoping beyond hope that someone was making new repros. | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | That brace would be easy to reproduce yourself if you have the old one for a pattern. You could cut the threaded ends off and weld new threads on fairly easy. Mike B  | | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | That, or cut new threads on some fresh rod stock. I agree, it seems doable to make one. The flat center would be the toughest to duplicate but if you have that much weld some new rods on and thread them. | | |
