5 members (Rustnut, Donf, Gdads51, Charles in CA, lumbersawyer), 63 guests, and 3 robots.
Topics128,203
Posts1,057,414
Members48,471
This on a 1954 235 truck motor. Does anyone know the part number for the rubber grommet in the oil pump screen? It attaches the screen to the tube coming out of the oil pump and the screen is bolted to the main cap. Or where to buy one? Getting ready to start assembly and noticed the grommet is hard as a rock. Don't think this will seal the screen to the tube on the oil pump. Thanks for any help.
I have always made it a rule to replace the oil pump if I had the engine apart. That said:
From the parts interchange manual you are looking for the grommet, pump suction pipe, p/n 3835868
http://chevy.oldcarmanualproject.com/parts/1929_54/132.htm
Obsolete Chevy parts shows this part
http://www.parts123.com/parts123/yb.dll?parta~partsort~1~cadeflkx
Do not order via the computer. Call 1-800-248-8785 to be certain you get the correct part.
Fred
52 3600
69 C-10
Thank you very much Fred!!!
