Hi all
I took the floorboards out to put the steering column back in. I need to know what is the correct order of replacement is. Is it toe board then floor board or vice versa?
Also, I am missing the piece of the toe kick that goes above the the brake, steering column and clutch. I looked on line and could not find one. It looks like it bolts to the firewall and lower toe. If you have a picture it would be a great help. I think it may be something I have to fabricate.
While I have your ear, The accelerator rod binds when going through the toe kick. It appears it goes through some sort of bushing, little bubble looking thing, it that right?
Thanks in advance
Andy
