7 members (GMCJammer51, walter74, JW51, 3B, J Lucas, Joe H, 1 invisible), 85 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#1099628 04/27/2015 3:24 AM
I have a 54 235 block with a slight curve in the bolt pattern on one side of the block. I bought a pan that was supposed to be for a 54 but it has a straight bolt pattern. I saw a listing for a 58-62 pan that seemed to have the right bolt pattern. Was there a change in mid year 54? Is a car 235 pan different than a truck?
Still trying to get ole Betsy back on the road.
There was a change in pans between 1954 and 1955 on car engines and first series 55 and second series 55 in trucks. I suspect the date code of your block will be late 54, and was actually installed in a 1955 car.
Another possibility is that it was a crate engine sold much later. I have seen these. They look like 54 engines but use the later pan style.
Does yours have a single large hole in the block for the water pump or two smaller?
My Blog
