3 members (carbking, GMCJammer51, 1 invisible),
224
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | I AM WONDERING IF ANYONE HAS A GOOD LOW COST IDEA FOR A BED FLOOR FOR A 53 PICKUP? EVERYTHING I TRY TO COME UP WITH SEEMS TO COST AROUND 200-300. ANYBODIES HELP WOULD BE GREAT. THANKS | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Piece of plywood is about 20 bucks.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | Piece of diamond plate isn't too bad.On my truck I am using bed floor out of 88 up swb chevy truck that I got free from body shop scrap pile ,building mounts and tacking in. | | | | | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | I used a piece of oak plywood, 3/4", about $50.00. Cut it to length. Sealed it on the bottom and stained and varnished the top. I split it down the middle so each piece would slip under the side rails. I then just attached the strips on top. It does not look too bad for a cheap fix. Rick  | | | | | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | I have a piece of 1/4 inch diamond plate in my longbed. Cost $83. No other changes. Anybody wants to lay down a wood bed can yank it and use a kit.
Never start vast projects with half vast ideas.
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | where did you all get that 50 inch wide plywood? | | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | Rick,
I'm intrigued by your description of your oak plywood bed. Did you attach all the metal strips so it looks like a regular wood bed? Do you have a picture of it you could post?
Thanks | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | A friend did the plywood thing on a F..d pickup. Just drilled holes and put down the strips to attach. Used cheap plywood rather than oak. Looks OK but not as pretty as oak ply would. If you really wanted to make it look cool you could use a router to cut grooves for the strips to get them down a little. | | | | | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | I used just three of the strips but you could use them all if you wanted to. My truck is a 46 so it's a little different then the AD's
Rick | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have a sheet of 3/4 exterior plywood in my bed. It is heavy. No need for the 300 layered varnish or expensive marine stuff. I slip it in the back, slide it under one side of the strips, it will fall to the frame, and then slide it over under the other. I try to get it centered. And I don't worry that it is not 50 inches. Mine hasn't slid around (it is probably held in place by the carriage bolts which hold down the cross braces) so I don't bolt it down. That's cool, saves money on the strips and other nuts and bolts.
Simple, easy, and inexpensive. I use my 55 as a truck. What ever I want to through in the back goes there. And most of my truck is primer. Guess I look like a redneck. Maybe I will paint it next year.
Oh yeah. When this sheet gets worn out I will replace it with a fresh one at Home Depot. Maybe I will drive it in a parade.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | RETREAD, I LIKE THE IDEA OF THE DIAMOND PLATE. NOW I JUST HAVE TO FINE SOME. AND THANKS TO ALL FOR THE IDEAS. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I was wondering about the sheets of plywood they use for freeway signs. I forget what the stuff is called but it paints up real nice and I believe it come bigger than 48x96.
Personally I will use an oak kit and every time I use the truck that might damage the bed, I will use a loose piece of plywood for protection.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | Tony M. I know exactly what you're talking about. I believe it's called MDO board. Sign painters use it because one side has a real smooth finish.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
| | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Has anyone ever used or seen anyone use Preasure treated lumber for the bed? Just wondering?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | With my experiences with pressure treated lumber, it would be awful for a truck bed. My parents' house is 25 years old, the exterior is pressure treated lumber, and the treatment is still leaching back out of the wood. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Over here on the west coast it is used for structural only and it is usually very rough wood. I think on the east coast they have better grades because of the lack of redwood, they use it for decks. The pressure treatment from 25 years ago is totally different than the current process. The chemicals used are different as well.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you decide to use the bed strips you can get two sheets of ply, rip one down the center and install it butted to the sides, then cut a slice off the other piece to fill the gap in the middle. Install the bed strips over the gaps and no one will ever know! You can even use marine plywood if you want it to last longer. Be sure to seal the ends and edges before installation.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2002 Posts: 2,854 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,854 | Has anyone considered PING PONG table plywood ? Guess what size it comes in.....Yes 60" x 108". The only issue is that it's 5/8" thick but that didn't stop me a year ago. Had the local supplier rip it 49.5" x 77". Slid in right in. Attached some SS strips on top and whola.... With all the support underneath I didn't worry for a second about being 1/8" thinner. I've hauled many yards of nursery mix and this is how it's looking today. http://www.cmaynard.com/Truck/truckbed.jpg Oh yes, for you who want to somewhat protect your wood finish during those messy runs to the dump or from hauling bricks, dirt, etc, get a sheet of rubber liner mat from matdepot.com. It comes 48" wide and as long as you want it. Cheers...
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you can actually get plywood in any size at a place that sells ply for marine use - the ply floor on a task force panel truck is somethin like 5' wide and 8' long, and can be obtained here through a Windsor Plywood store - cheaper to split and join sheets tho
Bill | | |
