3 members (Pre '68 Dave, 52Carl, Bill Marlow), 50 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
#1098482 04/20/2015 7:25 PM
I bought a column shift 1953 enclosed drive shaft 3 speed trans. Will any parts from this trans swap with my 55.2 3 speed open drive shaft column shift trans? Example: side cover, shift forks, cluster gear etc. Other words is it worth hanging on to, so I have extra parts for my 55.2 trans?
TIA. Brian
Brian
1955.2 3100 Truck
P Online: Content
Cluster gear fits 1940-63. Not much else will swap.
My Blog
You may be able to use parts from the side cover depending on which type you have. There is the ball type and the scissor type. The 2-3 shift fork will interchange the 1-R will not.
As Dave states, that's about it.
Fred
I was hoping the 53 4 bolt side cover with one shift arm up an one down would interchange on my 58 3speed overdrive trans that has both arms pointing the same direction, so I could install it in my 55.2 3100 which has the one arm up and one arm down set up.
Brian
1955.2 3100 Truck
P Online: Content
The low-reverse slider gear and shift fork are wider starting in 1955.
My Blog
I was able to overcome that issue but I don't recall how.
You can use the later 1-R shift fork in the early side cover providing they are both the same style.
Fred
It seems like that's what I did but it has been so long ago I can't recall for sure. The only 'problem' I have is if I leave my hand on the shifter in first gear, the gear slightly rubs another gear.
Brian,
If that's the transmission you got from me, it's an open drive line model, not a torque tube model. It was out of a 54 3/4 ton.
Chris
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
P Online: Content
A 1954 3/4 ton 3 speed transmission is the same as the 1948-54 torque tube type, except Chev adapted a strange bushing, seal, and yoke to the rear to make it work with a open drive shaft.
My Blog
Chris that would be the tranny I'm talking about. Dave, Fred and Cletus, thank you for your replies.
Brian
1955.2 3100 Truck
