1 members (Otto Skorzeny),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Are the doors on a '53-3100 identical to a '54-3100?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Pretty sure they are, cmayna. I'm sure someone will chime in if I'm talkin' outta my [censored], though. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | Cmayna, he's right the doors are the same. I believe that GM started vent windows in 1950, but the doors from 1948-1955 1st are all the same except that 48,49,50 have no vent windows.  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | cmayna,
I am not sure they are exactly the same because the '54 cardboard side cover is not attached with screws - it is attached with push-in clips. I am not sure if the holes for the clip are threaded as in the '53.
Also, the lower hinge cover uses smaller headed screws on a '54 - I am not sure that the depression in the cover and the hole size are the same.
In either case, the doors appear to be the same.
Tim | | | | | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | The other item that changed during the Advanced Design era was the door handles. The early designs had turn down handles and the later models (53 included) had push button handles. The holes cut into the doors do not match. I can't recall off hand what year the change was made, maybe someone else can chime in with that.
Steve 55 1st Series 3/4 ton
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Check out this link - great reference for the year-by-year changes in the AD line: ChevyTrucks.org Advance Design ID Guide The only major difference in the doors was the introduction of vent windows for 1951, and the addition of push-button door handles in '52. | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | GM changed the door latches and striker plates around 1952, not sure if the strikers and or latches can be swapped. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1954 door had a black button on the window crank (later years did too, but I do not know what years). Earlier handles had a maroon button (I do not know how many years back).
Tim | | |
