| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I've got a left and right wiper motor for my 42 but the switch handles don't line up with the covers. Before I take everything apart I thought I would ask for ideas. I have installed them with the flat side down and round side up. If I cock them a little I can make the lever fit but it is a little tight. Also they only have one switch lever on each motor. I guess the speed control was taken off when they were restored. I was told they were poor design and always leak. Should I stick with these and cover the extra holes or look for different motors? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Your truck originally had two knobs per motor, and the L&R motors are different part numbers. If you have good original motor covers, I would be apprehensive to alter them as they are hard to find.
Sounds like your project is coming together. | | |
